#1 Posted : Sunday, 26 September 2004 6:50:04 AM(UTC)
hey guys
which would give the best result on an alloy inlet manifold sand blasting or bead blasting
#2 Posted : Sunday, 26 September 2004 6:04:40 PM(UTC)
wayno, where are you??
#3 Posted : Monday, 27 September 2004 4:54:04 AM(UTC)
Crushed walnut will be kinder to the alloy.
#4 Posted : Monday, 27 September 2004 9:22:05 AM(UTC)
Theother thing is if you buy one of those cheap little sandblast kits they are about $30 at Super crap, the pressure you can put out from your 15 or 17cfm compressor is only about 100psi, which won't harm the alloy too much unless you concentrate on one s
This page was generated in 0.102 seconds.
