#1 Posted : Tuesday, 5 October 2004 5:47:12 PM(UTC)
gidday guy's, i am getting my old 308 rebuilt from scratch. i will be running it on straight gas. i have been told it is best to give it its first start on petrol. this will be difficult because of the gas system. any thoughts????
thanks
#2 Posted : Wednesday, 6 October 2004 5:10:25 PM(UTC)
You have been told bullshit....Give "gas research" a call if you hve any doubts.
#3 Posted : Wednesday, 6 October 2004 5:17:17 PM(UTC)
straight gas is just that no petrol.
if you are rebuilding the motor I believe there is a gas cam and gas only carbs if the motor is set up correctly it should be no less powerfull. use a flash lube kit also for the valves.
Maybe consider removing the p
