are all tie rod ends the same size i know there is left and right hand threads this for hq wb cheers
i do think they are just did mine on hq..there is inner and outer.... i the inner didnt fit the outer thats how i knew i had the wrong ones...
what was diff about the inner and outer vintage?
different part # also inside wouldnt fit out side that when i realised there different
Hi Guys.
As john asked in his first post, are they the same except for their threads ? One has a right hand thread & one has a left hand thread.
Dr Terry |
i asked because when i removed the rubber boot on the inner it is larger hence a larger diameter groove it sits in cheers ps and left and right hand threads
