Joined: 1/03/2005(UTC) Posts: 241  ![Australia Australia]() Thanks: 3 times
Has anyone modified a HKTG Powerglide shifter to use on a Turbo350 gearbox? The manual selection doesnt worry me just to put it in D and go., Whats the difference in the linkage from shifter to box? is it longer shorter or same position?. Any knowledge would be appreciated. Paul |
Jesse Jesse Jesse, you've not got a sense of humour! |
Paul. Sell the Powerlide shifter and use a trimatic one. Youll end up with change.
Paul. Sell the Powerlide shifter and use a trimatic one. You'll end up with change.
Byron, isnt the linkage on the other side of the box for trimatic? cheers Paul |
Hi Guys.
All HK/HT/HG auto trans floor shifters have their linkage on the LH side.
You can use a Powerglide shifter for a TH350, you just need to change the end of the rod to suit the TH350 lever. The levers length may also need altering to make the |
Hi Guys.
You can use a Powerglide shifter for a TH350, you just need to change the end of the rod to suit the TH350 lever. The lever's length may also need altering to make th |
