#1 Posted : Saturday, 24 November 2007 10:27:41 AM(UTC)
I have a bunch of air con compressors to suit VK to VR . Don't know if 6 or 8, but probably the same anyway.
no brackets or fittings.
These were wreckers stock so most came off crashed cars, so not worn out stock.
But No Guarantees, as is.
Inlet and intake holes have been sealed so probably have original oil and no crap, but no guarantees.
$10 each plus postage.
#2 Posted : Sunday, 25 November 2007 1:39:28 AM(UTC)
hey john, i really need a compressor, maybe two? but i am in vic nsw boeder? near echuca?? how much would it cost to send one or two here???
I will have to make my own brackets? is it worth it?
FB
#3 Posted : Sunday, 25 November 2007 10:33:40 AM(UTC)
Will have to check postage, probably about $30 thwe two, which ones would you want? Later ones have different pulleys, ribbed belts not V belts.
#4 Posted : Monday, 26 November 2007 11:18:25 PM(UTC)
Hey FB,
If the postage from Perth is outa control then i also have some compressors just outa some WB Statesmans. Im only 3 hours from Echuca on the SA/Vic border...
They have brackets to suit Holden V8.
Cheers, Luke.
#5 Posted : Monday, 26 November 2007 11:18:25 PM(UTC)
Hey FB,
If the postage from Perth is outa control then i also have some compressors just outa some WB Statesmans. I'm only 3 hours from Echuca on the SA/Vic border...
Cheers, Luke.
#6 Posted : Tuesday, 27 November 2007 9:58:20 AM(UTC)
Luke I find it a bit rich that you hijack my thread why dont you start your own ?
#7 Posted : Tuesday, 27 November 2007 9:58:20 AM(UTC)
Luke I find it a bit rich that you hijack my thread why don't you start your own ?
#8 Posted : Wednesday, 28 November 2007 1:50:49 AM(UTC)
Stay calm dude.... it's only a $10 compressor (with no guarantees)....
#9 Posted : Wednesday, 28 November 2007 1:50:49 AM(UTC)
Stay calm dude.... its only a $10 compressor (with no guarantees)....
Duzty Offline
#10 Posted : Wednesday, 28 November 2007 1:53:34 AM(UTC)
Duzty
You have been a member since:: 29/06/2005(UTC)
ooo what a snake! haha
Rare Spares Perth (REX SPARES) Representative. If you have an enquiry, feel free to message me. To shop online directly from Rare Spares
#11 Posted : Wednesday, 28 November 2007 9:44:49 AM(UTC)
Im calm just pointing out you are out of order. You are not even a registered member.
I have no problem with you doing your own advertising just hijacking someone elses.
Common courtesy.
#12 Posted : Wednesday, 28 November 2007 9:44:49 AM(UTC)
I'm calm just pointing out you are out of order. You are not even a registered member.
I have no problem with you doing your own advertising just hijacking someone else's.
Common courtesy.
#13 Posted : Wednesday, 28 November 2007 9:52:31 AM(UTC)
Anyway the VL one with single pulley weighs in at about 6kg, postage to Vic would be either $$20-70 or $24-90, don't know your postcode.
A VK one with double pulley (suit power steering or alternator maybe?)
and adjustment bracket but not main bracket
#14 Posted : Wednesday, 28 November 2007 9:52:31 AM(UTC)
Anyway the VL one with single pulley weighs in at about 6kg, postage to Vic would be either $$20-70 or $24-90, dont know your postcode.
#15 Posted : Wednesday, 28 November 2007 9:35:08 PM(UTC)
Get a grip John in Perth...
Luke is just helping out a guy only 200km away instead of 3500km away with postage.
Why dont you check out the add for - Tailshaft TH400 & 3.55 WB Diff plus heaps of others.
They are all taken over as well by someone e
#16 Posted : Wednesday, 28 November 2007 9:35:08 PM(UTC)
Why don't you check out the add for - Tailshaft TH400 & 3.55 WB Diff plus heaps of others.
#17 Posted : Thursday, 29 November 2007 11:09:33 AM(UTC)
well holden guy, anonymous, I give a flying f**k, who gives a rats about what you say ? you don't have the courage to identify yourself. I could say gutless, but that would be over the top. i probably shouldn't even bother to reply to you.
Why should
#18 Posted : Thursday, 29 November 2007 11:09:33 AM(UTC)
well holden guy, anonymous, I give a flying f**k, who gives a rats about what you say ? you dont have the courage to identify yourself. I could say gutless, but that would be over the top. i probably shouldnt even bother to reply to you.
Why should I
