Hi all. What oil do you recommend for a newly reconditioned 355 stroker and does it need running in? If so, how many km's and recommended max revs do you suggest?
Dave
penrite do Running In oil....
Rare Spares Perth (REX SPARES) Representative. If you have an enquiry, feel free to message me. To shop online directly from Rare Spar
Joined: 29/07/2006(UTC) Views messages in topic : 766 Location: in the shed
Thanks: 8 times Was thanked: 14 time(s) in 13 post(s)
To run her in . . . . . get in and drive for an hour or two. The worst thing you can do is potter around like grandma does, and the second worse thing is give it sh*t. Just go for a cruise up through the hills and vary the speeds and loads (Hills kinds d
The main thing is to use non friction modified oil in it to let the rings bed in. If you drive it up and down hills as Rigpig stated you are varying the load on the engine which is a good thing. Try not to stay at the same revs for prolonged periods of ti
