Hi All Were you able to order sandmans with options,airconditioning-power steering-power windows-etc,etc.Or were they just a set package only? Cheers Rob.
Easy Come-Easy Go |
There Is No Replacement For Displacement. |
They were a package, but there were still some options. I am sure you could get the air and steer but power windows would not be available.
Warren
yes warren i believe that is correct. PS on the V8 may have been standard also? |
not standard - well not on any of the utes I owned.
Hi Guys.
I read the Sandman option thing a bit differently.
Firstly, The Sandman was a limited-production option package in the HQ series. That means they were produced a bit like the HQ SS in that they werent pre-ordered. They were made in batches |
Hi Guys.
Firstly, The Sandman was a 'limited-production' option package in the HQ series. That means they were produced a bit like the HQ SS in that they weren't pre-ordered. They were made in batch |
Im sort of with Terry on the HQ. Most seem to be a certain driveline, with the only options other probably limited to dealer fitted stuff. Having said that though I do have a build sheet for an actual ordered HQ XX7 Sandman ordered with side windows and I |
I'm sort of with Terry on the HQ. Most seem to be a certain driveline, with the only options other probably limited to dealer fitted stuff. Having said that though I do have a build sheet for an actual ordered HQ XX7 Sandman ordered with side windows and |
