Does anyone have a quick fix for an air conditioner that does not blow out the front vents? It seems to work correctly sometimes but most times it does not. You can hear it trying to work properly. I know its a vacuum problem but don't know how to fix. Any help would be appreciated.
2 possibilities:
1. Vacuum supply: From the manifold, to the check valve, accumulator, and into the car - check all the hoses & pipes.
2. Vacuum switching: This is achieved by an electro-solenoid/vac switch pack, mounted under the console, in fron |
