Is E38 T350 or T400 Wb statesman
cheers in advance
RB
p.s. did anyone check out the 375hp Morris minor in stuff nz..??
M38 is TH350 in HZ and WB. TH400 is HZ only and is M41.
Hi Guys.
To add to what Byron has said, GM-H did something a bit strange with the numbers, back then.
When they changed from TH400 to TH350 in the HZ & VB (mid-79) they kept the same PO number (M41) on the body plate. When their replacements came ou |
