ash05 Offline
#1 Posted : Sunday, 13 January 2008 7:18:13 AM(UTC)
ash05
i need help i have $4500 to spend on a new engine to replace my clapped out 308 and th400in my HZ 1 tonner. which way should i go i have thought about vs 5ltr conversion i can get hold of one with a tranny for $3300 but is it as easy as bolting it in and away i go will my cuurent th400 cross member match the new tranny is there anything else i need to know, getting an engineers certificate how much could that cost? how difficult could that be as the car is unreged and will be going for a rwc with the new engine. i thought about getting a 350chev create long motor carby asperated. i realy dont know which way to go the car will be a daily driver i do want to be able to get in and hit the key and know it will fire every time which is why i'd like to go with the Vs 5ltr but i dont want to spend $3300 on the engine trans and the find out i need to spend another $3000 to get it on the road. any help would be much appreciated i would have liked to have with the LS1 with auto but i dont seem to be able to locate 1 second hand for less than $6000
Edited by user Sunday, 13 January 2008 7:24:39 AM(UTC)  | Reason: Not specified
witcheshollow racing team Offline
#2 Posted : Sunday, 13 January 2008 7:11:26 PM(UTC)
Well I dont know the thoughts of others but I will give you my idea of how you should go about it. $4500 these days is not a lot of money to throw at an engine, so I would rebuild the 308 that you already have, dont over kill it just a good solid bottom e
"Such is life"
#3 Posted : Sunday, 13 January 2008 7:12:15 PM(UTC)
Was thanked: 611 time(s) in 578 post(s)
You'll find a complete VN/VP 304 and TH700R4 conversion in running order for less than $2,500. On top of this (assuming your radiator is OK) you'll need:
Swirl pot;
Return line to fuel tank;
2 pulse speed sensor from Kalmaker;
Exhaust;
Tailshaft le
#4 Posted : Sunday, 13 January 2008 7:12:15 PM(UTC)
Youll find a complete VN/VP 304 and TH700R4 conversion in running order for less than $2,500. On top of this (assuming your radiator is OK) youll need:
Swirl pot;
Exhaust;
Tailshaft leng
bundybluedog Offline
#5 Posted : Sunday, 13 January 2008 8:00:10 PM(UTC)
bundybluedog
My brother in-law gets all his cars put in the shop for some reason and he is getting a VN 5ltr 5 speed coneversions done $3500 including instalation all he has to do is drive it home, engine has 120,000 on the clock and has 6 month waranty. if he did it
#6 Posted : Sunday, 13 January 2008 10:24:55 PM(UTC)
#7 Posted : Sunday, 13 January 2008 10:24:55 PM(UTC)
#8 Posted : Sunday, 13 January 2008 10:27:54 PM(UTC)
#9 Posted : Sunday, 13 January 2008 10:34:53 PM(UTC)
Also forgot you need to get a brass T-piece off the manifold of a Holden 6 so you can put a T in the oil pump sender hole and run the EFI pressure sensor and your guage sender.
If we all had the
#10 Posted : Sunday, 13 January 2008 10:37:41 PM(UTC)
#11 Posted : Monday, 14 January 2008 2:41:12 AM(UTC)
bundybluedog
nah mate he is in clontarf not far from brisbane grunt automotive
#12 Posted : Monday, 14 January 2008 4:04:10 AM(UTC)
how well, id be happy to pay up to $4500 to drive it in to someones shop and drive it out again with the new motor.
#13 Posted : Monday, 14 January 2008 4:04:10 AM(UTC)
how well, i'd be happy to pay up to $4500 to drive it in to someones shop and drive it out again with the new motor.
Guest (9)
This page was generated in 0.083 seconds.
