#1 Posted : Wednesday, 16 January 2008 1:26:22 AM(UTC)
anyone on here had any experience with the small portable sandblasting tanks (see pic), Im thinking of getting one but would like to know how good they are, I have a air comp capable of running one & can get a good quality grit, but are they worth it? I will have lots of further use for it, if it works...
thank's
Kevin
Edited by user Wednesday, 16 January 2008 1:28:28 AM(UTC)  | Reason: Not specified
peter_flane Offline
#2 Posted : Wednesday, 16 January 2008 6:46:05 AM(UTC)
peter_flane
For small parts, works good. Would take a day to do a panel.
#3 Posted : Thursday, 17 January 2008 8:01:27 AM(UTC)
Make sure you can get parts noozle etc.seen one wear the noozle in about 1hr/ not even 1/2 a quard using garnet.
#4 Posted : Thursday, 17 January 2008 9:05:56 AM(UTC)
too expensive for what is basically a tin can to hold the sand. also clutters the shed when not in use.I use a 20 litre drum for the sand and a el cheapo $30 sandblasting gun from someone like autocheap have used them a fair bit and nozzle is still good t
