have 308 with engine number qt123330 cast date a2b2 could somebody advise what this was out of ta!
HQ 308. Cast date 28 Jan 72.
James
You only have to be in front at the end of the race. |
Recheck the casting date. Should be 2b/1/72, so whatever the b is in numbers eg 6 so 26/1/72.
Does anyone know what an NT engine number is
Nasco or GMP&A replacement 308 short motor for HQ-HZ.
Byron are you keeping records of NT engine # and casting dates? If so i replaced my 11QT stato/tri block last year in my HJ coupe to go turbo pattern to fit my T700R4 trans and ended up getting an NT numbered block with casting date 13J7 from the wrecker
