#1 Posted : Monday, 25 October 2004 4:27:58 PM(UTC)
What "holds" the LCD speedo reading in a VN Calais' etc?
Is it a part of the ECM, or is there another module that records this?
Can it be reset/changed?
I've acquired an HSV VR GTS engine and gearbox, and want to change the speedo reading in my VN Calais to match the actual mileage of the new engine when I do the swap.
Can I use the VR dash (if need be) as it looks to be the same as the VN Calais?
#2 Posted : Tuesday, 26 October 2004 5:09:52 AM(UTC)
The odometer is held in an EEPROM inside the trip comp module. It can be changed by a VDO agent.
The VN & VR dashes don't swap as the pinouts of the plugs on the back are different, and one way around (I can't remember which) results in a plume
#3 Posted : Tuesday, 26 October 2004 6:20:19 AM(UTC)
Thanks Mick.
Don't know why I didn't just email you :-)
