hi can someone help with decoding theses LH plates please
Body LH8VD69 LH 5/74 Trim 188119V paint 56715823 eng L31 box M21 diff GU8
I thinks its a 4 door slr5000 but not sure
cheers Alan
Drive carefully! Remember, it's not only a car that can be recalled by it's maker |
sure is...
going to church makes you no more a christian than standing in a garage makes you a car... |
All SLR5000's are 4-doors. As Greg says it is an SLR5000 in Saffron Metallic with black vinyl trim. Be VERY careful of it though if GU8 is the correct diff code. It may just be a mistake and meant to be GU7 (2.78) but GU8 is a 4cyl diff (3.90:1) which I |
All SLR5000s are 4-doors. As Greg says it is an SLR5000 in Saffron Metallic with black vinyl trim. Be VERY careful of it though if GU8 is the correct diff code. It may just be a mistake and meant to be GU7 (2.78) but GU8 is a 4cyl diff (3.90:1) which I d |
thanks Byron and Greg..... code is GU7 it was a typo on my part....
has anyone got a pic of a saffron metallic car as this car is now blue
cheers alan
cheers alan
Drive carefully! Remember, its not only a car that can be recalled by its maker |
