Hi guys just wanting to know if it is ok to just put a switch on the dash for your windshield washer, will it pass a roadworthy? I have looked everywhere with my testlight to find the original wire but no go, its on a HQ. Also can i use a button on the dash that is within easy reach for my horn?
Blade
HQs only use a button for the washer anyway so you should be OK with a button. Id say you wont get away with the horn on the dash though.
_______________________________________________________ If we all had the same (good) taste, who would buy all th |
HQ's only use a button for the washer anyway so you should be OK with a button. I'd say you won't get away with the horn on the dash though.
_______________________________________________________ If we all had the same (good) taste, who would buy all |
The original wire is dark blue from the wiper motor to the washer part of the wiper motor. I seem to recall that the switch actually works as an earth. That is, the power to the washer is always there and pressing the button beside the wiper switch comp |
__________________________________________ Keep the shiny side up, and the greasy side down. |
