is it true that the late model duel cab holden ute diff can replace the hq banjo and has the same bolt pattern ? cheers
Hi john
If youre talking about a Crewman, this has the normal Commodore 120mm PCD wheel stud pattern, which is NOT the same as HQ.
Not sure about the length, they would be very close to HQ width though. I will have a measure.
Dr Terry. |
Hi john
If you're talking about a Crewman, this has the normal Commodore 120mm PCD wheel stud pattern, which is NOT the same as HQ.
Dr Terry. |
