joelm Offline
#1 Posted : Wednesday, 19 March 2008 8:46:57 AM(UTC)
joelm
hi all,
its time to get the EJ wagon reprayed and i need some recommendations on who to go to.
i am in bendigo and would prefer local- but will travel to melbourne or ballarat if the quality is affordable and good.
would be cut to bare metal, then 2packed. no rust to cut out other than v minor surface on base of doors.
thanks in advance.
peter_flane Offline
#2 Posted : Wednesday, 19 March 2008 9:06:45 AM(UTC)
peter_flane
I have a friend who lives in Bendigo half of the time, and he does good work. He will only do bare metal, and in two pack. He does only high standard work, and can do show car work too. He usually starts his prices at $8000. He is booked for the whole of 2008 already. It may be out of your budget, or not work within your time frame.
The surface rust on the lower of your doors is guaranteed by 99% to be rust that has made its way from the inside and finally is showing on the outside after eating all the way through the door outer panel. Sorry to dissapoint you, but you will need to be prepared for another $1-3 for panel replacement sections to be done properly. There may be more found in the bottoms of front guards, rear quarters, around back windscreen, rear lower back panel, and bottoms of doglegs.
peter_flane Offline
#3 Posted : Wednesday, 19 March 2008 9:06:45 AM(UTC)
peter_flane
joelm Offline
#4 Posted : Thursday, 23 July 2009 8:53:45 AM(UTC)
joelm
Hi peter,
thanks for the reply. does your friend still do work in bendigo?
how booked up is he for 2009?
Thanks.
peter_flane Offline
#5 Posted : Thursday, 23 July 2009 9:31:22 AM(UTC)
peter_flane
He is available as far as I know, e-mail me your details and I will put you in contact with each other. You can make your decisions based on his own personal direct contact.
