Is there a HQ or HJ or Torana indicator switch mechanism that has a headlight flasher function? I don't mean the later version with the headlight switch.
only the floor mounted one, unless you want to change the steering coloum and wire one up.
quote: Originally posted by mrhqute
Is there a HQ or HJ or Torana indicator switch mechanism that has a headlight flasher funcEdited by user Friday, 28 March 2008 6:46:28 PM(UTC)
| Reason: Not specified |
Thanks Dr. Terry. Torana parts are getting hard to get. Ill have to see if I can find one somewhere.
Thanks Dr. Terry. Torana parts are getting hard to get. I'll have to see if I can find one somewhere.
A mate says he had a HJ GTS coupe with hi/lo and flash on the indicator stalk. Is this possible? Maybe a late model HJ? Or maybe his memory is failing him.
Ross
