#1 Posted : Saturday, 5 April 2008 5:55:25 AM(UTC)
I have a 9" diff housing with 1 tonne axles to suit a HQ-WB ute but no centre or brakes. It was made by C & F Engineering in Toowoomba and uses the standard Holden tubes, axles and brakes. I also got a drain bung fitted to the housing. It would have done less than 1000 km in the ute I had so is still in good condition. $400.
Phone 0427 350 461 for details. Can be inspected in Brisbane next week if required.
#2 Posted : Saturday, 5 April 2008 6:31:43 AM(UTC)
Was thanked: 632 time(s) in 594 post(s)
Howd the tailshaft go hung off to one side? Did it clear the fuel tank OK?
#3 Posted : Saturday, 5 April 2008 6:31:43 AM(UTC)
How'd the tailshaft go hung off to one side? Did it clear the fuel tank OK?
#4 Posted : Sunday, 6 April 2008 5:42:56 AM(UTC)
Hi Byron,
I didn't actually have any clearance issues with the original Holden fuel tank in my ute but went for a new housing arrangement when I put the alloy tank in, but yes they can run close in some utes. I also had the shorter yoke which may make a
#5 Posted : Sunday, 6 April 2008 5:42:56 AM(UTC)
Hi Byron,
I didnt actually have any clearance issues with the original Holden fuel tank in my ute but went for a new housing arrangement when I put the alloy tank in, but yes they can run close in some utes. I also had the shorter yoke which may make a d
#6 Posted : Sunday, 6 April 2008 6:34:04 PM(UTC)
OK. I'd seen it done before and noticed how close the tailshaft comes to the tank. There is actually a better way to do what you have done, and that is to use VN axles. They are exactly the right length for HQ-WB and put the 9" yoke in the centre. They us
#7 Posted : Sunday, 6 April 2008 6:34:04 PM(UTC)
OK. Id seen it done before and noticed how close the tailshaft comes to the tank. There is actually a better way to do what you have done, and that is to use VN axles. They are exactly the right length for HQ-WB and put the 9" yoke in the centre. They use
