how can you tell the difference between the standard rims that fit on a disc brake front end and the drum brake? my standard rims scrape on the disk
Thanks: 1 times Was thanked: 243 time(s) in 217 post(s)
Hi edmundo.
Holden used the same rims for both disc & drum brakes in those models. Contrary to popular belief, there is no special rim for disc brakes.
HD rims are different to HR rims. The offset is different & is identified by the HR rims having a |
thanks Dr. terry i have an ej with the disc brake front end. cheers
