when fitting a later disc rear under a hq do the threads on the brake pipes of the hq match those of the later metric fittings ?oao thanks
Thanks: 1 times Was thanked: 243 time(s) in 217 post(s)
Hi john.
You've almost answered that question yourself. No, they don't fit because they are 'metric'.
It's easy to overcome though. I can make new hoses with a metric fitting at one end & an imperial fitting at the other. Or I can cut the pipe fit a |
Hi john.
Youve almost answered that question yourself. No, they dont fit because they are metric.
Its easy to overcome though. I can make new hoses with a metric fitting at one end & an imperial fitting at the other. Or I can cut the pipe fit a metr |
