#1 Posted : Saturday, 19 April 2008 9:20:51 PM(UTC)
Item: 545 cu in BBF for sale
Price: $14,900
Condition: New
Description: 460 BBF stroker, 545 cu in
OEM 460 block bored 0.030" with torque plate
RPM forged crank 4.5 inch stroke
RPM forged H beam rods with ARP rod bolts 6.8 inch long
Diamond forged custom piston
Diamond plasma moly rings
Lunati flat tappet solid cam & lifters 271/279 @ 0.050 0.641/0.641 lift 110 LSA
FRPP SCJ Aluminium heads, bowl blended, (peak flow 360CFM int/240CFM exh)
ARP head bolts
ARP main studs
Mains tunnel align honed
TFS roller rockers 1.73:1 ratio
TFS 3/8" push rods
11.2:1 static compression, runs on pump fuel
Victor 460 single-plane intake
Melling high volume oil pump
Cloyes true roller timing chain
Front mount oil sump
Engine is brand new, and just completed test fire and camshaft break in by engine builder. The motor is currently in the States where it was built by professional engine builder specializing only on 460 based engines. Motor will land in Melbourne in a few weeks time, crated up and complete from intake manifold to sump.
Motor will make 650+ HP and 650+ FT/LBS on pump fuel, these figures are very conservative.
Bottom end is internally balanced, and all forged, good to way over 1000HP.
Engine comes as new, with all paperwork. Genuine reason for sale, all questions answered. Pictures available.
Mobile: 0438 563 386
Email: [email protected]
Chris.
