Peterxx83 Offline
#1 Posted : Saturday, 19 April 2008 10:54:29 PM(UTC)
Peterxx83
OK, the kids were playing in the front seats and they broke the indicator stalk. I've bought a new one, and I've got the steering wheel off, but what's next?
Do I need to take the dash facia off to get to the bottom of the steering column?
Peter
Natmeisterus Offline
#2 Posted : Sunday, 20 April 2008 5:10:23 AM(UTC)
Natmeisterus
Hi peter. The indicator is held in by a screw, im sure you could see that from the drivers seat. The wires that go down the steering column have a clip/harness thing which should end just under the dash, you wont have to take off the fascia to undo the cl
Peterxx83 Offline
#3 Posted : Sunday, 20 April 2008 7:59:52 AM(UTC)
Peterxx83
Thanks Nat, The problem was that I had actually bought the wrong replacement stalk. I believe I bought a WB Statesman Series II Indicator stalk whereas I needed a Series I (1982) stalk. This has a longer cable. I was getting confused as the broken one ins
#4 Posted : Sunday, 20 April 2008 9:01:43 AM(UTC)
Commodore stalks are the same (in appearance) as WB ones, but the cable is only half as long - you probably got one of them instead.
A lot of people aim to achieve noth
