3 Pages<123>
mrhqute Offline
#21 Posted : Monday, 5 May 2008 8:18:36 AM(UTC)
mrhqute
I also believe that tags are just another part.
If you have a body which is stuffed, I don't see anything wrong with putting those tags on another body. After all, if there was say 300 GTS's there still are 300 GTS's.
I do have a problem though, if some
mrhqute Offline
#22 Posted : Monday, 5 May 2008 8:18:36 AM(UTC)
mrhqute
If you have a body which is stuffed, I dont see anything wrong with putting those tags on another body. After all, if there was say 300 GTSs there still are 300 GTSs.
I do have a problem though, if someone
hainzy Offline
#23 Posted : Tuesday, 6 May 2008 8:02:58 AM(UTC)
hainzy
Agreed MR HQute.
I agree that there is a difference nbetween having the real car and replacing the rooted bits including the shell, as compared to creating a new ie fake car.
If you have a genuine monaro with all the GTS bits, correct engine, orig int
#24 Posted : Tuesday, 6 May 2008 9:04:46 AM(UTC)
Originally posted by hainzy
Copying the compliance numbers off an ebay car, then getting tags made up and putting the
#25 Posted : Tuesday, 6 May 2008 6:29:39 PM(UTC)
Why on earth would anyone need photos of tags to make fake ones? Unfortunately its not that hard to make up enough numbers to make yourself a unique HK GTS327 or HT GTS350 or HQ GTS350 coupe or whatever, and that is without using numbers off any existing
#26 Posted : Tuesday, 6 May 2008 6:29:39 PM(UTC)
Why on earth would anyone need photos of tags to make fake ones? Unfortunately it's not that hard to make up enough numbers to make yourself a unique HK GTS327 or HT GTS350 or HQ GTS350 coupe or whatever, and that is without using numbers off any existing
JBM Offline
#27 Posted : Tuesday, 6 May 2008 6:36:59 PM(UTC)
JBM
Originally posted by Byron Rich
There are brand new Monaro bodies still kicking around for V2 and VZ and what is wrong
#28 Posted : Tuesday, 6 May 2008 8:29:34 PM(UTC)
Probably. But how many of these do you think would get used and not have the original car's VIN plate attached. AFAIK the plates are just rivetted on and the windscreen covers the rivets.
If we a
#29 Posted : Tuesday, 6 May 2008 8:29:34 PM(UTC)
Probably. But how many of these do you think would get used and not have the original cars VIN plate attached. AFAIK the plates are just rivetted on and the windscreen covers the rivets.
If we al
mmazz30 Offline
#30 Posted : Wednesday, 7 May 2008 3:39:52 AM(UTC)
mmazz30
I also think the Vin # is stamped on the floor in front of the passenger seats
#31 Posted : Wednesday, 7 May 2008 6:19:32 AM(UTC)
Originally posted by 81837
I'd agree that a rebody is OK because it does not increase the number of a type of car, but
#32 Posted : Wednesday, 7 May 2008 6:19:32 AM(UTC)
Id agree that a rebody is OK because it does not increase the number of a type of car, but m
#33 Posted : Wednesday, 7 May 2008 6:33:02 AM(UTC)
The above comment was meant for "WE WRECK 81837S ONLY" ...........Buddy, you should take a serious look at yourself in terms of your provocative and pathetic nature.
I think we should start a petition to get you off this site! From what I have observe
#34 Posted : Wednesday, 7 May 2008 6:33:02 AM(UTC)
The above comment was meant for "WE WRECK 81837'S ONLY" ...........Buddy, you should take a serious look at yourself in terms of your provocative and pathetic nature.
#35 Posted : Wednesday, 7 May 2008 7:11:31 AM(UTC)
You dont serve a purpose either Jess. On ya horse.
sandmanxx7 Offline
#36 Posted : Wednesday, 7 May 2008 7:48:22 AM(UTC)
sandmanxx7
i think i heard a toilet flush....
#37 Posted : Wednesday, 7 May 2008 6:28:53 PM(UTC)
A BROCK COMMODORE A MUSCLE CAR????????? OH MY....
"ALL WE LEAVE IS MEMORIES.."
"ANYONE CAN RESTORE A CAR, BUT IT TAKES BALLS TO CUT ONE...."
#38 Posted : Wednesday, 7 May 2008 7:27:50 PM(UTC)
I have read this throught now I ask for specific advice. I owned some time ago a HZ GTS. The shell was rotted badly and wrecked by me. Since I am still in posession of all tags, engine/gearbox, interior, gaurds, dash and wheels, is the general consensus t
JBM Offline
#39 Posted : Wednesday, 7 May 2008 7:38:41 PM(UTC)
JBM
As long as nothing is misrepresented it should be fine, if its sold as a GTS with all matching numbers then this is obviously fraud as the body doesnt belong to the tags.
James
You only have t
#40 Posted : Wednesday, 7 May 2008 7:49:45 PM(UTC)
So by that token, a replacement body shell ex holden would need to have been ordered "as a gts" rather than a generic hz shell.
Or is the real issue that the replacement shell started life as another car eg. kingy then used to create a gts.
How woul
3 Pages<123>
This page was generated in 0.098 seconds.
