i want to put electronic ignition in my HQ Targa car will a dizzy from a blue/black motor work also i want to fit a good manifold with a larger carby, what is a good brand, car only used for racing so the bigger and badder the better all ready have a large cam and headers with 3 inch pipes any help guys Edited by user Wednesday, 28 May 2008 6:54:05 AM(UTC)
| Reason: Not specified
Blue or EFI black dizzy will fit straight on. Just needs 12V, where standard red is 9V with resistance wire in the harness, so you need to run a bypass wire from an ignition feed to the coil. Also use a coil off the same car the dizzy comes from. Regraph |
cheers mate would love to fit triples but money and wife say no, have a line on a twin carby setup, just trying to find out manifold make
another question
up grading HQ brakes, any ideas
Hi blue, black dizzy ok , 2 single barrel cabies no, go with 2 barrel 6cly holden then. or ford xf webber on 2 barrel holden manifold. Tony.
if the twin carby set up is X2 type I know some one who wants one and I have GTR or 186S type manifold and WW carby
If you are on a budget go with the 186S manifold and WW Stromberg or Weber.
Hoppers Stoppers for brake upgrades.
Redline twin stromberg manifold. part no: 12-66.
