Davesmonaro68 Offline
#1 Posted : Tuesday, 3 June 2008 11:52:37 AM(UTC)
Davesmonaro68
i have several diff here from vb-vk and there is 2 different sorts .
One has 10 bolts but looks smaller than a normal salsbury and the other has 9 bolts presum its a borg warner. are the gears inter changeable and also are they the same as banjo gears .
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
#2 Posted : Tuesday, 3 June 2008 4:06:06 PM(UTC)
If the drive flange is flat & round, then its a bog-warner/BTR diff.
If the drive is a uni-joint type yoke, then its a salisbury.
The borg-warner diffs cover plate is shaped somewhat like an octagonal stop sign, with flattened off edges around the per
#3 Posted : Tuesday, 3 June 2008 4:06:06 PM(UTC)
If the drive flange is flat & round, then it's a bog-warner/BTR diff.
If the drive is a uni-joint type yoke, then it's a salisbury.
The borg-warner diff's cover plate is shaped somewhat like an octagonal stop sign, with flattened off edges around the
#4 Posted : Tuesday, 3 June 2008 11:31:28 PM(UTC)
Davesmonaro68
cheers Commodorenut thanks for the info.
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
