Higher compression (10.5:1), LPG cam, timing set for LPG, straight gas. But only if you can go straight gas. If its going to be dual fuel youll have to compromise.
_______________________________________________________ If we all had the same (good) t |
Higher compression (10.5:1), LPG cam, timing set for LPG, straight gas. But only if you can go straight gas. If it's going to be dual fuel you'll have to compromise.
_______________________________________________________ If we all had the same (good) |
Gday all, I am speaking on behalf of BorisHJ as i will be helping him out with the build. as far as i know we will be running the car on straight gas once this engine goes in. the car is running a celica 5 speed currently so we dont want anything that w
Gday all, I am speaking on behalf of BorisHJ as i will be helping him out with the build. as far as i know we will be running the car on straight gas once this engine goes in. the car is running a celica 5 speed currently so we don't want anything that
