hazzard county Offline
#1 Posted : Sunday, 22 June 2008 4:21:47 AM(UTC)
hazzard county
looking at my big nut the over day & noticed it was a bit rusty.thats my brake master cylinder i talking about of course & cant quite read the date code all i can see is "disc " & at the end were the date code should be all i can see is the letter "p" what would the date code read is it the same as the steering box date should they be simular or exact dates
Edited by user Sunday, 22 June 2008 3:28:25 PM(UTC)  | Reason: Not specified
80737k Offline
#2 Posted : Sunday, 22 June 2008 4:27:50 AM(UTC)
80737k
I've got a good master cylinder to use on my HKGTS but it's not the big nut type. Any advantage to getting a big nut one other than just to be correct for a GTS ?
"Junk is something you throw out three weeks before you need it"
Fossil fuels are YUMMY !
80737k Offline
#3 Posted : Sunday, 22 June 2008 4:27:50 AM(UTC)
80737k
Ive got a good master cylinder to use on my HKGTS but its not the big nut type. Any advantage to getting a big nut one other than just to be correct for a GTS ?
#4 Posted : Sunday, 22 June 2008 5:57:07 AM(UTC)
hazzard county
as far as working wise makes no diff but i had mine stainless steel sleeved so it never stuffs up again so if your looking at a car which sits around alot ss sleeves the way to go so if you going to ss sleeve it you might as well spend the money on the co
80737k Offline
#5 Posted : Sunday, 22 June 2008 10:05:32 AM(UTC)
80737k
Thanks for that, always wondered. Once our Munro's finished, it'll be rego'd ASAP and then it'll be in full daily service, reckon i'll hardly be out of the thing :-D
80737k Offline
#6 Posted : Sunday, 22 June 2008 10:05:32 AM(UTC)
80737k
Thanks for that, always wondered. Once our Munros finished, itll be regod ASAP and then itll be in full daily service, reckon ill hardly be out of the thing :-D
