YetAnotherForum.NET Help
Bossy Offline
#1 Posted : Wednesday, 2 July 2008 6:54:13 AM(UTC)
Bossy
My XP runs a pre-crossflow 250 with a 3.50 diff through the original 3 speed box. This means at 100kph it reving at 3000rpm. What are my options to lower the revs and fuel consumption? Change diff? Or is there a gear box with a ratio that will improve the situation?
#2 Posted : Wednesday, 2 July 2008 11:45:07 PM(UTC)
Yes Change diff ratio or better still get an XF T5 gearbox. I believe that you can also buy an adapter plate that bolts onto the back of a 250 3 speed bell housing and a T5 bolts to that. This enables you to use the more readily available EA onwards T5.
Bossy Offline
#3 Posted : Thursday, 3 July 2008 3:08:23 AM(UTC)
Bossy
Thanks! Sounds like its the way to go. I see the final drive ratio of a T5 is 0.79:1 where as the current box is 1.00:1. Where do I get the adaptor plate?
#4 Posted : Friday, 4 July 2008 12:42:59 AM(UTC)
Dellow or CRS Had them.
www.dellowauto.com.au
www.rodshop.com.au
If at first you don't succeed then skydiving is not for you.
Bossy Offline
#5 Posted : Wednesday, 16 July 2008 3:53:08 AM(UTC)
Bossy
Jim, what bell housing do I need to marry the T5 to the pre-crossflow 250?
#6 Posted : Wednesday, 16 July 2008 10:08:17 PM(UTC)
You could use a 4.1 crossflow XF T5 bellhousing straight on your 250. EA onwards ones are different and have the starter motor on the wrong side for an OHV ford 6.
