Docktor Offline
#1 Posted : Tuesday, 15 July 2008 2:08:48 AM(UTC)
Docktor
Ok. I have 2 coupes.
XB JG67 RP XXXXX K
Trans B - 3 sp cruisomatic t bar auto
Trim P2 - Parchment with cloth insert
Paint 7 - Walnut Glow Metallic
Engine Y - 302
Extra Codes - 27 , 28
__________________________________________________________________
XC JG65 TE XXXXX K
Trim B - Black
Paint 9 - Sno white
Engine T - 351 4V
Extra Codes - 29 , 31 , 34
My ideas.....
The xb is a 302 fairmont from 12-75. It has rear flute holes in the rear quarters, and aircon cut outs in the firewall. What do the extra codes depict and anything else you can tell me about the car ?
The xc was a sydney based police pursuit coupe. I have the letter from Ford to verify but if any one knows anything else it would be appreciated.
does the K following both numbers signify a K code coupe or ???
Doc
Paul351xb Offline
#2 Posted : Tuesday, 15 July 2008 2:35:18 AM(UTC)
Paul351xb
K at the end of the engine number denotes that it's a V8. A K code car refers to the compliance plate where the engine is a factory 351 2 barrel. That's on the XA and XBs. With XCs it is represnted with a T. All XC V8s had the factory 4 barrel.
T cod
#3 Posted : Tuesday, 15 July 2008 6:47:12 AM(UTC)
This page . http://www.fomoco.com.au/ID.html
Shows my XC T coded engine as being a 351 - 4V. Am i wrong in assuming that the 4V stands for 4V heads ?. does it in fact mean 4 venturi ? Like you said I agree with you saying 351 xc's had 4BBL carbs on em. C
Paul351xb Offline
#4 Posted : Wednesday, 16 July 2008 3:46:32 AM(UTC)
Paul351xb
4V heads stopped in 1973/74. It's confusing I know but yes the T code 4V stands for 4 venturi. In the case of the XCs onwards it was the 4 barrel thermoquad. All XC clevos had 2V heads from the factory.
The rest of your codes you listed have me stumpe
#5 Posted : Wednesday, 16 July 2008 7:07:22 AM(UTC)
where did you find these extra codes?
#6 Posted : Wednesday, 16 July 2008 6:27:57 PM(UTC)
#7 Posted : Thursday, 17 July 2008 8:37:07 AM(UTC)
They are on that fomoco site,
29-side door strength
31-hydraulic brake system for passenger cars
34-child restraint anchorages and anchor fittings
Code 27 on the XB is emissions and 28 is external noise of motor vehicles
#8 Posted : Tuesday, 22 July 2008 4:49:54 AM(UTC)
Thanks mate, I had a look on the page but cant see where ya got em from. All good, back to rebuilding the xb i guess.
Doc
#9 Posted : Monday, 25 August 2008 10:58:25 AM(UTC)
Those numbers are ADR reference. Each number represents what the car should have.
I have a pdf file somewhere that tells you what they all mean. They means things like
seat belts mandotory, must have a warning device, must have lights, must meet this pa
Guest (10)
This page was generated in 0.105 seconds.
