Can anyone help Has anyone converted VR 304 injected turbo 700 computer controlled gearbox back to manual speedo cable into HZ Ute, Or does anyone know if this can be done. Kind Regards Mechelle
if you mean running your old speedo with the a mechanical driven cable, there is a couple of ways to do this, one way to do this is, I think its castle auto electrics who can modify your HZ speedo so it’s now an electric driven speedo, second way is to bu
Daniel
Why wouldn't you just have bought a T-piece or an inline speed sensor?
Daniel
Why wouldnt you just have bought a T-piece or an inline speed sensor?
hi mate It was awhile ago when i did this, but i think it was because you cant buy a mechanical speed drive fitting that comes out of the transmisson and then has a t section with one running to the mechanical driven speedo and then the other side to sen
