I have 2 sets of HG HT 308 heads one is dated 1970 the other 1969 i noticied the ones from 69 have no accesorie bolts holes on the pasengers side? are these rare or just normal. cheers dan |
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
Hi bundy
Its not that they have no accessory holes on the front of the LH head. They only have one bolt less, there are still some holes in that spot.
The older ones with one less hole, should have the casting number 7449033. The newer ones should b |
Hi bundy
It's not that they have no accessory holes on the front of the LH head. They only have one bolt less, there are still some holes in that spot.
The older ones with one less hole, should have the casting number 7449033. The newer ones should |
