#1 Posted : Friday, 25 July 2008 8:49:48 PM(UTC)
i was looking at engine oil coolers , some by perma cool.
are these anygood ? worth buying. for mild v8.
is it possible for the cooler to make the oil too cold and damage/crack engine components ?
same question with my coolant actually. i have a 4 core radiator with 16" cure blade fan.
possible to crack heads , should i be running a thermal switch or can i just have it on constantly ?
thankyou
also i have an old set of crane rollers, not sure if its worth putting them on , they have 1 or 2 chips in them.
one more thing lol, i have a gear drive on my old motor, what does a gear drive offer? also how do i check for wear ?
thankyou 4 any help
#2 Posted : Sunday, 27 July 2008 2:09:02 AM(UTC)
ANYONE ????
THANKS
#3 Posted : Monday, 28 July 2008 3:59:16 AM(UTC)
come on plz i need an answer to sumtuing
tanart Offline
#4 Posted : Monday, 28 July 2008 8:23:05 PM(UTC)
tanart
dylan, i have twin thermos on my HT GTS 350 and they are set to come on at a certain temperature range. You dont want them on all the time. Make sure you run a thermostat to the right temperature of you engine. I'm running a 180 F and the thermos are set
tanart Offline
#5 Posted : Monday, 28 July 2008 8:23:05 PM(UTC)
tanart
dylan, i have twin thermos on my HT GTS 350 and they are set to come on at a certain temperature range. You dont want them on all the time. Make sure you run a thermostat to the right temperature of you engine. Im running a 180 F and the thermos are set a
