Fastlane
Holden Forums
Holden General Discussion
VL on ultra low springs with cat back illegal???
i have a vl with ultra low springs and a 2.5" catback... is this legle... i just goy my ps and live in vic...
youll more than likley be pulled up for the hieght of the car if ya can fit a can in between the muffler and groung you should be right.
you'll more than likley be pulled up for the hieght of the car if ya can fit a can in between the muffler and groung you should be right.
P-plates, VL, and Victoria - you don't even need anything illegal to be hassled in a VL down there!
But yes, the 100mm ground clearance rule will be what they ping you for, so make sure absolutely everything under the car clears 100mm, otherwise they w |
P-plates, VL, and Victoria - you dont even need anything illegal to be hassled in a VL down there!
But yes, the 100mm ground clearance rule will be what they ping you for, so make sure absolutely everything under the car clears 100mm, otherwise they wi |
hhmm? what amazes me is they carry on about car noise,, and yet the noise is nothing compared to any harley that drives by?? no most trucks?? this always intrigues me? cheers bcb
ptpro some men see things as they are, and ask "why" I dream of th |
more than basketcase than a bear! DOH!!! |
thanks does anyone know if ultra low springs will still clear the 100mm rule...
the cat back makes a bit of noise but not overly loud
Fastlane
Holden Forums
