Can someone interpret these date codes please: 17M8 16F0
17/12/68 16/6/70
Thanks Byron. Would you say the 16/6/70 one is correct for my 7/70 Monaro? Who should I talk to about fixing a 16.7:1 box with free play in the straight ahead position, or should I take the internals out of the '68 Brougham box and fit to the '70 body? I
Thanks Byron. Would you say the 16/6/70 one is correct for my 7/70 Monaro? Who should I talk to about fixing a 16.7:1 box with free play in the straight ahead position, or should I take the internals out of the 68 Brougham box and fit to the 70 body? Im
Dr Terry is your man for rebuild info. Warren will have a better idea than me on the correct date code, although I reckon it's maybe 2 weeks too early.
_______________________________________________________ If we all had the same (good) taste, who wo |
Dr Terry is your man for rebuild info. Warren will have a better idea than me on the correct date code, although I reckon its maybe 2 weeks too early.
_______________________________________________________ If we all had the same (good) taste, who wou |
No that would still be ok, as the 16.7:1 boxes were not always that close.
Warren
Do all steer/boxs have date codes on them ? I have 4 i need to clean up also how do you tell what ratio they are is there a easy way to tell by nos
My code is
11L8D
its 11/11/68 but whats the D for?
