6pak Offline
#1 Posted : Sunday, 28 September 2008 4:14:32 AM(UTC)
6pak
Hi All, My ZD Fairlane has a glitch with the indicator that I'm keen to sort out while I have the dash out and the steering wheel off. At the moment if I turn right the indicator cancels normally when I straighten up out of the corner. When I turn left however, it over cancels and indicates right when I straighten up out of the corner. The mechanism seems to be all there with nothing broken off. I changed the column from a column shift to a floor shift which has left the honey pot able to be turned a quarter of a turn with your hand. Is this as simple as grabbing a new cancel mechanism or is it related to ripping all the column shift gear out?
