HQforme Offline
#1 Posted : Friday, 17 October 2008 5:02:17 AM(UTC)
HQforme
On a manual steer 72 Kingsood. I can see how badly worn it is because it travels several mm before engaging the steering arms. Is it a bushing, or the arm itself?
"Silly modern cars"
#2 Posted : Friday, 17 October 2008 7:42:53 PM(UTC)
Hi There, sounds like your drag link need replacing. If the pitman arm is moving on the splined shaft from the steering box then the nut is loose or you have a more serious problem which could be the spline is worn on the arm or box.
You need to determi
pont69 Offline
#3 Posted : Friday, 17 October 2008 7:47:24 PM(UTC)
pont69
get someone to jump in the car and steer for you, then carefully check it all the links. it could be lose nuts, could b worn spline or even be in the box. Just take a close look at everything. cheers
Get your feral little mittens off it!
Cheers, James
