Ado Offline
#1 Posted : Friday, 17 October 2008 9:58:58 PM(UTC)
Ado
Looking to fit a WB statesman diff,2.6:1 and Disc Brake to a HZ V8 sedan. Just wondering if it goes straight in. The HZ in question has rear disc so are all brake lines/hoses the same? Is the sedan drive shaft OK to use. Also can the sway bar of the sedan bolt straight up to a WB diff of vice versa. Hoping changing the diff to the wb 2.6 will make for nice and tidy fit.
Ado
#2 Posted : Friday, 17 October 2008 10:38:46 PM(UTC)
HZ and WB disc brake diffs are identical. V8 sedan tailshaft will fit. Make sure grab the speedo driven gear too off the WB assuming your HZ has the same gearbox. Both diffs should have sway bar mounts on them.
#3 Posted : Friday, 17 October 2008 10:50:47 PM(UTC)
Hi Ado.
Everything should fit, the only differences AFAIK are the threads on the brake fittings.
All the pipe fittings on the WB are metric, whereas the HZ ones are all imperial (inches).
Just use everything except the brakes.
Dr Terry.
Ado Offline
#4 Posted : Sunday, 19 October 2008 11:57:59 AM(UTC)
Ado
Thanks alot for replying. Didnt think of the change from AF to metric.
Ado.
#5 Posted : Monday, 20 October 2008 7:03:54 AM(UTC)
Ado Offline
#6 Posted : Tuesday, 21 October 2008 3:55:51 AM(UTC)
Ado
Thats fine, always looking to gain knowledege!
Ado.
Guest (5)
