Hi All, is it worth the money to have underbody sound deadener applied,and does it work? Its for a VZ ute,to hopefully reduce some road noise. Cheers.
There Is No Replacement For Displacement. |
Yes Luke go with the Wurth products weve done all our trucks with it and may the force be with you.
Joined: 2/03/2005(UTC) Posts: 491 ![Australia Australia]() Thanks: 3 times Was thanked: 8 time(s) in 8 post(s)
Robbo, have just finished a ute using Wurth deadener, fantastic stuff and so easy to use(spray) but make sure you use the water based product. AL.
Thanks for the info guys,Wurth products it is. Cheers.
how does one geta hold of this wurth sound deadener and how much is it ?
Its available at any decent automotive place or maybe like us we buy direct from the Wurth distributor. May the force be with all you guys.
