#1 Posted : Monday, 29 December 2008 7:34:14 PM(UTC)
Hi,
Besides a HK/T/G unit, are there any other factory v8 diffs that will fit into a HK without modification, ie HQ / HZ etc?
Matt
#2 Posted : Tuesday, 30 December 2008 2:09:06 AM(UTC)
68/69 Camaro. Just have to attach the HK-HG hangers. Possibly not even that (I have to measure one up one day as I want a 12 bolt for my HK).
VB-VK 10 bolt and VL V8 and turbo Borg Warner is about 25mm narrower both sides. Also needs brackets.
HQ-WB
petaus Offline
#3 Posted : Tuesday, 30 December 2008 6:49:34 AM(UTC)
petaus
did any of the hk,s have twelve bolt diff factory???? if so who,s got one????
adam PERTH Offline
#4 Posted : Tuesday, 30 December 2008 7:06:25 AM(UTC)
adam PERTH
apparently the 12 bolt were an option on 81837 cars only.
i have a 12 bolt diff drum to drum out of a pontiac.(1590mm wide)
needs to be shortened 40 mm either side to fit under HK. $500.
The all the gears and LSD centres are still available for the
#5 Posted : Tuesday, 30 December 2008 7:36:01 AM(UTC)
Yes, optional on HK 1837 and HT 1837 manual only. Ratios 3.55 and up. Impossible to find. I have seen one only ever, and know of one car that had one from new (Norm Beecheys HT). Problem with the 12 bolt is they are a bastard of a bearing that wears out t
petaus Offline
#6 Posted : Thursday, 1 January 2009 8:17:59 AM(UTC)
petaus
wow i wish i was loaded
jimmy64 Offline
#7 Posted : Sunday, 4 January 2009 11:03:52 PM(UTC)
jimmy64
Is anyone interested in a 12 bolt that has had commy discs put on instead of the drums? A bloke I was talking to yesterday said he had one for sale!!
#8 Posted : Monday, 5 January 2009 2:52:47 AM(UTC)
Yes, if its a 12-bolt from a HK-HG. Email me if so.
jimmy64 Offline
#9 Posted : Monday, 5 January 2009 3:55:02 AM(UTC)
jimmy64
if you give me your email address i will send you his mobile next week (as I only have his number at work and I dont go back till Thursday)and you can talk to him direct, I think he said he got it from a ute but it might have been a HQ but you never know?
Guest (10)
