Gday,
Can anyone tell me if there is a body number on the actual body of a HJ or is just on the plate above the firewall? I have been told there is one but just can't seem to find it.
Cheers Peter
Some plants put numbers on which dont correlate to the plates or chassis number but you can tell when a body has been swapped if you have enough knowledge or records. This will stuff up more than a few peoples plans with body swaps on HQ-HZ Sandmans, coup |
`Check on the firewall to the left of the heater, there should be a body number there.
Cheers, Pete. Old Holdens never die, they just go faster. |
That is one spot.
Ok HK1837 Ill bite, where might there be other places for it. Mine is an adelaide build if that helps at all.
Cheers Peter
