Is the hk monaro on ebay at the moment an original woodsman green colour
looks that way. must be special order
Yes it is , my very first Monaro was a standard (non GTS) HK 186s 4 Speed Woodsman Green Monaro with Buckskin Beige Trim . And i know Les Guthrie in Bairnsdale has a Factory Special order HK 327 Monaro in this colour also .
Check my new website for ple
I have a Woodsman green HK 337, was 186 3spd with LSD. 18X trim. It is a very early July 68 build. I plan to use the quarters and early illars off it on my Pagewood 327 (all damaged in speedway use), and will probably put the flared quarters and late pill |
Mine is Woodsman Green with 18X. Would it be correct to assume that any Woodsman Green car would be a reasonably early build, as carried over from HR?
Could be. It also might be a special order like the Warrigal black and burgundy maroon examples.
