hey yall, i have a t400 that is very slowly leaking out of the changer arm seal. just wondering what is involved in replacing this seal? being in a 98ford transit, it is a straight drop out for the pan,,easy access etc? cheers bcb
said the weathercock to the wind,> "how tedious and monotonous you are, can you not blow in any other direction, but in my face!" and the wind did not answer, it just laughed in space. k.g/ |
more than basketcase than a bear! DOH!!! |
Not a job for the inexperienced.
You need a special tool to R & R the seal & you must not scratch the selector shaft, otherwise the seal, wont err!! seal.
Not an expensive job at an automatic repair shop.
Dr Terry. |
thanks doc, i put some wynns down it,, but would rather make it right,, thanks bcb
said the weathercock to the wind,> "how tedious and monotonous you are, can you not blow in any other direction, but in my face!" and the wind did not answer, |
