keithholden Offline
#1 Posted : Tuesday, 23 June 2009 6:22:05 AM(UTC)
keithholden
I had the wire arc out that goes from the coil to the condensor, the plastic part broke and it arked on the dissy where the slot is.
I went to remove the points to replace them and the pole is stuck in the dizzy, only way I got the points off was removed the pin through the pole.
Is the pole suppose to come out???
or is it welded in there from when the ark happened ??
Cheers Keith
http://img200.imageshack.../img200/5899/dizzyz.jpg
http://img268.imageshack...550/pointsnewandold.jpg
Browno Offline
#2 Posted : Tuesday, 23 June 2009 6:26:44 AM(UTC)
Browno
i think the pivot would be stuck on there from factory i think there r two different types ones that have it stuck on and once that slips through the hole that come with the points... i hope that made sense
Drive It Like You Stole It......Drive it lik
Drive It Like You Stole It......Drive it like you own it
keithholden Offline
#3 Posted : Tuesday, 23 June 2009 6:30:57 AM(UTC)
keithholden
The dizzy is a bosch type, ill see the parts guy tomorrow and see if he has a different type.
Ive been swinging on the pole so hope its not to badly damaged.
Bugger.
If any one else would like to comment ill check back tomorrow morning befor
keithholden Offline
#4 Posted : Thursday, 25 June 2009 7:01:37 AM(UTC)
keithholden
yep you were right, the pole is part of dizzy. got it sorted cheers :)
