hi guys, i am trying to figure out what a monaros running gear was, it was made late december 69 and is a ht 80837 and has the hole cut out in the middle of the floor and a speedo cable in the centre ish part of the firewall,six inch wheel brackets and humped fuel tank any ideas?
308 Saginaw or Powerglide. Saginaw linkage hump (or not) will determine manual or auto. Manual will also have radius rod bracket holes in the body.
