Does anyone know how to reset the service indication on the dash for a VZ Holden.I have the manual for the VT but they must have changed the setup for the VZ
From memory you press the up and down arrows on the trip computer then turn the ignition on. Once it beeps remove your fingers and itll ask you what to reset. I think this is right, I did it a few months ago on my Cross8.
Yes it does ask you if you want to confirm the reset but not sure what then to press
