ned351 Offline
#1 Posted : Monday, 3 August 2009 8:19:44 PM(UTC)
ned351
i have had my fmx re conditioned and now only when it it cold it will not engage reverse,only when warmed up after about 4 minutes ,it will engage forward 1st and 2nd ok but will not go into 3rd at all until about 4 kilometres, when hot, i use Castrol "TQF" oil which I thought was recommended---any suggestions will be appreciated- thanks ned351
302Superbird Offline
#2 Posted : Tuesday, 4 August 2009 6:36:29 AM(UTC)
302Superbird
Silly question, have you checked your oil level? Can't remember if they checked are hot and running?
If it is anything like my XA coupe (C4 auto) she does not like to go anywhere before 4 minutes of warming the engine up anyway!
Good luck with it,
Sco
ned351 Offline
#3 Posted : Tuesday, 4 August 2009 8:57:27 PM(UTC)
ned351
Thanks,Scott,I don't know why I overlooked the obvious, probably because I am colourblind and should also put my reading glasses on..This time I got my missus to confirm the fluid level(in park and warmed up} She said the fluid level is down so I topped i
Paul351xb Offline
#4 Posted : Wednesday, 5 August 2009 2:42:42 AM(UTC)
Paul351xb
Ned. is the vacuum hose connected from the manifold to the gearbox? If it isn't she wont change into top too well.
"Life, a series of events, woven into a tapestry which becomes our destiny"
#5 Posted : Wednesday, 5 August 2009 7:54:53 AM(UTC)
302Superbird
Aftermarket dipstick and tube??????? I know that there are 2 different length dipsticks and tubes for FMX boxes, but I would also query the correctness of an aftermarket jobby too! When it comes time to change the oil, I would double check the capacity wh
This page was generated in 0.120 seconds.
