Fastlane
Holden Forums
Holden General Discussion
327 block - worth anything or just scrap?
engine number 327##075 t0404h5 cast date d18 3914660 large journal was going to put this in my ute but its all too much work as it needs a bore.
The other two numbers are tha main thing, as this will tell you which plant th engine was sent to for fitment to a Monaro GTS 327. It will be worth something for the owner of h engine or a car built around the same time and plant.
Warren
great not scrap then, if it was in the mid teens how would you find out to which plant it went?
Mid teens is Pagewood. Ill give you good money for it as a spare for my 2 x HK GTS 327s if you want to sell it. Just PM me. Where are you?
Would be worth a $2000 minimum these days Grant if you put it on ebay , as genuine Numbered HK 327 Blocks are hard to get now . Dont give it away . There are quite few Aussie Delivered 67-68 Chevy 327 Blocks around which are really the same thing essentially , but the engine number with H5 , the state and the correct later date makes it worth it money assuming its not restamped . Would be worth more if you had the car to match it . www.monaromuscleparts.com
gee wiiz james thats alot of money for a block? i wish i had the car to match or even a base model but the ones that go for my price range on ebay are more useful as giant tea strainers then cars.
Fastlane
Holden Forums
