blackss Offline
#1 Posted : Saturday, 29 August 2009 4:38:28 AM(UTC)
blackss
help my plastic bucket of >>>> is falling apart.the abs fault light comes on sometimes while driving but not on start up it has done 80000kms is the car safe to drive or should i leave it.
petaus Offline
#2 Posted : Saturday, 29 August 2009 6:10:26 AM(UTC)
petaus
the light should come on when the ignition is first turned on then go out, if it stays on or comes on while driving there is a fault most abs systems i know off will turn them selves off if there is a fault. meaning the brakes will work except no abs (no anti skid) so yes you can still drive it but i would have it scanned (looked at as soon as you can)
what sort of car is it??
pete mechanic.
This page was generated in 0.022 seconds.
