Fastlane
Holden Forums
Holden General Discussion
How to Remove the chrome trim and windows on a Hg
Well Im sure this topic was discussed somewhere on the forum but can someone advise how to remove the chrome trim and windows on a Hg GTS Monaro ? Any help would be appreciated. Thanks
Front and rear windows are simply pushed out, need to be gentle and start in top corner, if laminated front screen you will need to cut the seal first, otherwise screen will break.
Once out chrome trim can be removed.
For side trim lowers clip in but have securing screwa, top back is screwed on and top front you need a small piece of timber and push lower edge off gently.
I would not remove rear quarter glass, a real bugger to re fit, but front door glass, take out 1/4 window and frame, one screww on lower side of 1/4, plus locating stud on rear pillar, bolts on frame and screws for 1/4 to frame.
Main glass requires regulator to be removed.
Warren
Thanks Warren
Will give this a try.
Fastlane
Holden Forums
